Close
Results 1 to 4 of 4
  1. #1
    Join Date
    Mar 2005
    Posts
    9
    Rep Power
    PW 50 front fork repair
    Hello all,
    I am rebuilding a PW50 for my grandson. I have the front forks off of the bike, but cannot get them apart. I have removed the circlip where I can see the fork seal, but I can't get the top to seperate from the bottom. I don't see any screws that I have missed. What am I not doing right? The bike is old, probably around a 90 model. It is yellow and black.
    Thanks for the help.
  2. #2
    Join Date
    Aug 2005
    Posts
    2,879
    Rep Power
    46
    Why are you trying to pull them apart?
  3. #3
    Join Date
    Mar 2005
    Posts
    9
    Rep Power
    I thought I needed to to put the fork seals in.
  4. #4
    Join Date
    Aug 2005
    Posts
    2,879
    Rep Power
    46
    Pull the spring out, extend the fork, top it off with oil, put the cap back on, clamp it in a vise, wrap a ratchet tie down around it, and tighten it until you can get the seal off. You might have to tap the seal back in a few times to keep it level. This is what I do with my son's KX.
    I do not believe that the PW50 has the typical fork seals, or even fluid that needs replacing. You should verify the usefulness of the procedure with your dealer service department before jumping into it. I do not believe that the PW50 has the typical fork seals, or even fluid that needs replacing. Also, the clymer manual doesn't list a fliud for the PW50 fork, or show a seal in the exploded view.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Similar Topics
  1. Where to buy Olin front fork springs ?
    By T-Bone in forum KTM / Euro Bikes
    Last Post: 05-29-2003, 12:05 AM
  2. Easy question!! Front fork spring replacement
    By tclark2020 in forum Canadian Daves JustKDX
    Last Post: 01-03-2003, 08:29 PM
  3. Front fork oil level
    By Kjetil in forum Mods, Performance & Repair
    Last Post: 06-24-2002, 07:50 AM
  4. stiff front fork on 89 cr 250
    By Mike Nester in forum Suspension Q&A with Jeremy Wilkey
    Last Post: 06-09-2002, 07:03 AM
  5. Smothness of front fork stroke??
    By d rockwell in forum Canadian Daves JustKDX
    Last Post: 01-27-2002, 08:41 PM
Members who have read this thread: 0
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
