Close
Results 1 to 4 of 4
Thread: Cdi
  1. #1
    Join Date
    Mar 2008
    Posts
    109
    Rep Power
    14
    Pulse Cover Generator (CDI cover?)
    Yeah, its me again. And now i sorta figured out whats going on. My xl185 honda keeps shorting out and shutting off whenever i put the cdi (it says CDI on it, apparently its called a Pulse Generator cover) cover back on. Where and why could this be shorting?
    its number 5 in the diagram
    Attached Images Attached Images
    m y   s i g n a t u r e:
    If superman and captain america raced to the moon, who would win? CHUCK NORRIS!
  2. #2
    Join Date
    Nov 1999
    Posts
    8,193
    Rep Power
    111
    If you look at the pulse coil #4, the wire that exits the case has a rubber grommet on it. I suspect that is where your problem is. If a large stress was placed on the wire, the insulation could have broken free, exposing the wire. When you put the cover on, you are pinching the wires together causing a short. Based on your discription in the other thread, it runs with the cover off, cuts out when you hold the cover on, and dies when you mount the cover.
    Get some heat shrink tubing, strip back the insulation on each wire, cover with heat shrink and try again. It may be necessary to replace the wire all the way from the pulse cool out of the case. Be sure to clean the connections and be quick with the soldering iron. Insulate and cover with heat shrink. I had to replace a pulse coil on my atv and broke one of the leads. After re-soldering the connection and covering with heat shrink, I put the cover on, filled with oil and the little 230cc engine runs great.
    Member of an angry mob, TAXPAYERS!
    2B Judged by 12, NOT carried by 6!
    05 YZ 250T, 05 Midnight Roadie, 05 Scorpa SY250, FB:BSwift
  3. #3
    Join Date
    Mar 2008
    Posts
    109
    Rep Power
    14
    thanks. I actually did just that yesterday, runs like a champ now
  4. #4
    Join Date
    Nov 1999
    Posts
    8,193
    Rep Power
    111
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Members who have read this thread: 0
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
