Originally Posted by matt-itude
I figure there is probably a fairly simple explanation.
and have no idea how it performs in my bike compared to other things. thanks!
Thought you all might enjoy that one. And thanks Rich for reposting your avgas article...it's one that should be stuck to the top of the forum as it comes up so much
Originally Posted by 2strok4fun
issed:
Originally Posted by Rich Rohrich
2) Depending on the refiner 100LL can have fairly high aromatic hydrocarbon content, in the 30% by weight range. This level of aromatics will tend to make the throttle response mushy and flat in applications that see big throttle opening transitions on a regular basis. It's similar to what happens when you dump a lot of Toluene based octane booster in your fuel. Throttle response becomes a distant memory.
There are at least 100 different threads on race fuel & AvGas that will explain all this in excrutiating detail.
Here's just one of mine that I found.... |
....Contrary to popular belief this isn't 100-octane fuel. Aviation fuels are rated on an ASTM Lean/Rich performance number system. 100LL is rated at 91/96 By comparison; Unocal Leaded race gas that is used in lots of spec fuel racing classes has performance number of 112/160. 100LL is closer to 91 octane (MON); by comparison VP C12 is rated at 108 (MON)....
vBulletin Copyright ©2000 - 2008,
vB Easy Archive Final ©2000 - 2008
