1969 Yamaha DT1 - timing
Posted by: Succubus
Ok, I finally have a spark on my vintage DT1. Can anyone suggest a way to set the timing? The bike has no battery. All the electrics are removed except the black wire off the alternor that runs to the coil. The other leads still come off the generator, but only the black is connected to anything. The only time there is juice is when I kick it. With no juice in the system, how can I tell when the points are opening so I can set the timing? Can I attach a battery to one of the other leads to power up the system long enough to check it? Surely someone has faced this before. Any help would be appreciated.
Posted by: originaldirt
You need a "buzz box" and a dial indicator set - up. Good Luck !
OD
Posted by: Succubus
The dial gauge I understand. I have to pull the head the get the correct distance before top dead center (3.2mm), so I figured to substitute my digital caliper. But what's a "buzz box." Most of my experience with bikes with points has been street bikes with batteries and I set timing with a timing light. I'm on unfamiliar turf here..... Thanks for your response.
A buzz box is a rather obsolete electrical device that uses a "buzzer or squealer" to indicate that the points are opening or closing. I have not looked for one in while , but I'm sure they are still available somewhere. I saw one in a Race car magazine for use in setting magneto points and they wanted $60. I had a buddy who made them for sale, and he got $40.00. He retired, moved and got lost. I'll try to find him.
OD
Posted by: Succubus
Thanks. If he isn't interested in making one, perhaps he can tell me how he makes them and I could fabricate something. I'm wondering if I could use a continuity tester to tell when the circuit is complete. But I have to check it without pulling the flywheel, since the flywheel has to be installed for the points to open at all. Not much room to work with there, through the little gaps in the flywheel....
Posted by: SFO
kowa seiki makes one, used to be an oem suzuki/yamaha/honda tool.
Try K&L for a new one.
All you have to do is to hook one of the leads to the hot wire running to the coil,the other lead to ground and the buzz box will read the points opening and closing from there.
I just checked www.kowatools.com and they wany $94.00+ for their buzz box "ignition tester" ,,,,yikes!!!!!
OD
Posted by: Succubus
Ouch!!!! If that's all you do to hook it up, why won't a test light work?
Posted by: SFO
you could also use a volt/ohm meter with a audible continuity circuit.
Or just read the meter.
Posted by: Succubus
I think that's the way I'm going to go. $94? That's insane....
Posted by: SFO
well, if you really need to borrow one, pm me.
Borrow means that, btw.
I also have the complete yamaha dial indicator kit.
All the factory kit for the price of shipping...
