Filter Skins ..
Posted by: c&b745XX
I just wondered what experiences anyone had with filter skins ?. It seems that they would be good for a, in between moto freshin up of your filter ..
Posted by: bikepilot
I've used them, they work more or less as advertised. I found that on my KX250 if I oiled the filter skin I had to re-jet to keep from being too rich and running poorly. for longer desert rides this is what I did and it worked well, though probably slightly down on power. Most of the time I ran filter skins without oil (but oild the filter as usual) - this worked well, not noticeable difference on engine perofrmance and it still stopped a noticeable amount of dust - not as much as an oiled filter skin, but still pretty good.
Another product I've not tried, but have heard good things about are the outwares pre-filters.
good luck
Posted by: ellandoh
same results here, i like em for the dunes
Posted by: yamayz125
I use skins. I ride very much in sand and the skin collects the dust.
Don`t have to change the airfilter so often as usual!
I don`t use so much oil at the skins, just a little bit (spray can filteroil).
Posted by: c&b745XX
My place is a very sandy track , a filter skin sounds like just the ticket .
THANKS........
