BIg Hands! What grips?
Posted by: theDogger
Was wondering what grips all those who have a glove size of 12-14 are using. I am looking for some jumbo sized grips.
theDogger
Posted by: nikki
As far as I know, all of the grips are the same standard size, since they are only the length of the throttle tube ( and the clutch side grip is the same length to match). Unless someone makes longer throttle tubes that I'm not aware of, but I don't think so?
No not the length.. ....Bigger in circumference. The diameter of the grip. With bigger hands you need a bigger grip. Think of it this way. With big hands would it be better to hang onto a pencil or a baseball bat?
See what I am looking for here.
theDogger
Posted by: YZ165
Try the Spider M1's. They feel about an 1/8 of an inch bigger around than "normal" grips. I didn't like them because they felt to big, but that's what you are looking for right?
http://www.spidergrips.com/2005/id2.html
Good luck, YZ165
Posted by: dirt bike dave
I have not had a set in years, but Pro Grips makes an oversize model. It is marketed as a dual sport 'gel' grip.
It is much thicker than a regular grip, and is supposed to reduce vibration.
Posted by: nikki
Doh, thicker grips. Gotcha.
Posted by: BigRedAF
Slim - small hands
Half waffle - med hands
Full waffle - large hands
Posted by: BigRedAF
Ops, old post, I need to go back to bed!
vBulletin Copyright ©2000 - 2008, Jelsoft Enterprises Limited.
vB Easy Archive Final ©2000 - 2008 - Created by Stefan "Xenon" Kaeser
