Originally Posted by Eric Gorr
Blue-print specs can be extrapolated from a factory service manual where service limit dimensions are published.
Originally Posted by mtk
...blueprinting is about putting them on the "good" side of tolerance.
Things like stacking up the tolerances for ... desired clearances... |
Originally Posted by Studboy
It doesn't seem right that they would run too much clearance in regards to the bearings. I thought that too loose would cause damage and too tight would just seize the bearing.
vBulletin Copyright ©2000 - 2008,
vB Easy Archive Final ©2000 - 2008
