Need a bolt off a 99 YZ 125
Posted by: CousinLarry
Does anyone have a 99 YZ 125 they're parting out? I need a bolt off the rear caliper - Not the pin that goes through the brake pad loops - I need the one on the front of the caliper - it's an M12 bolt that tapers down into a pin that goes into the caliper bracket.
I called a dealer, and they don't have it or know what it's called/where to get it..
Anyone have it??
Posted by: IndyMX
According to Bike Bandit, the closest they come is a 2004 YZ125 brake..
If you look at that one, you can see they have the slider pin available. It's cheap, so you may want to give that a try.
Otherwise, you might be looking at having to get a whole new caliper, which is gonna cost you quite a bit.
Hmm, I see what you mean - that does look like it. Just called them and they don't have the dimensions of the bolt. I know it's M12 with 1.25 pitch - that's about it.
I guess I'll try to order that, thanks for the lead..
Posted by: IndyMX
No problem!!
That one worked!! Thanks again for the lead!!!
Posted by: IndyMX
Whoot.. Good deal man..
Sometimes you just have to get creative.
vBulletin Copyright ©2000 - 2008, Jelsoft Enterprises Limited.
vB Easy Archive Final ©2000 - 2008 - Created by Stefan "Xenon" Kaeser
