1981 ke 125 carb problems
Posted by: Dylan19302
My dad and I picked up a 1981 KE125 from my friend. He said he did everything he could to get it to run but it would only sputter. Well we got it running and my dad rode it down the road and it stalled. It has a carb on the side of the engine. It only has a idle screw and I was wonder were is the air screw.
Posted by: digifox
tThe mixture screw is on the front of the carb. under the Engine cover
right under the throat....
also get a recommended plug and 1 hotter and 1 colder
And one gallon Leaded 110 octane (its about $5-7 per gal.) but it WILL clean out the engine and put a nice lead coating on the rotary valve and other parts...
(Trust me i`ve been running this stuff through my KD since 2006 and no rebuilds)
And Castrol Inj. oil is the best!
I dont see the adjusting screw. Theres one at the front of the carb that adjusts the idle but i dont see a air screw. There is a open hole right beside it but my friend said there isnt suppose to be one there.
Posted by: digifox
oh...looking at the diagram of it, it looks like a Reed Carb, but there is no Mixture screw....So IDK
so there is no air screw on it. also this bike is points right what is the gap supposed to be.
Posted by: digifox
Your best bet would be
a Clymer Manual
http://www.repairmanual.com/motorcycles/1981/34/0/4624
Thanks I was thinking of getting one but i dont know. Ill probally get one. but does any one have the point gap so i dont have to spend 27 bucks.
Posted by: sm7482
NO it is a rotary valve. all ke models are rotary valve. no theres probaly not an air screw. HAve you guys thuroughly cleaned the carb? also it's oil injection so make sure the oil tank is clean and has no air bubbles. clean the carb real well, then make sure the idle screw is set right. where would you even buy leaded gasoline? were are you located?
Posted by: digifox
Trust me a manual will come in handy many times!
Quote:
So is the KD, it has a idle screw and a mixture screw(Actually the KD and KE engines are the same)
And leaded gas would probably be available at a local Sunoco or somewhere that carries VP racing fuel(if you live close to some kind of race track to the station closes to it.)
We have cleaned the carbs really good. used carb cleaner, let them soak in this stuff my dad got, and poked wire down the jets. My dad thinks the carbs are fine but he thinks the timing is off does any one know what the points are suppose to be set to.
Posted by: digifox
Quote:
Get a manual *shrug*
it has EVERYTHING in and even has a troubleshooting in the back...
They have detailed instructions on everything diagrams and all that jazz
Posted by: sm7482
is the piston ok? with age they do where down to the point where the barely run, an example? here http://www.youtube.com/watch?v=d0yGP-tF_R0
also ive read in various owners manuals not to put wires through jets because you might open the holes biger than they should be. Remove the exuast and look through the exhaust port on the engine. Alot of times you'll get alot of carbon build up causing the engine to run poorly or not at all. make sure your throttle and oil pump work in unison. definatly try checking for carbon build up. OH and if your spark plug has excessive carbon build up and you repeteadly clean it with a wire wheel ect they won't work as well somtimes. get a new plug or a few of em.
Posted by: 2strokerfun
I've used wire from bread twistees many times to clean clogged jets and have never damaged a jet orifice. Just use relatively soft wire smaller than your hole.
Posted by: sm7482
or compressed air
Posted by: targis34
Its the Dad....heheh
The bike was suffering from "splooge". Oil getting past a seal and into the crank and gas. It was pouring out of thew tailpipe and blowing white smoke everywhere. Its currently waiting on new seals. My parts dealer says he can't get them. Anyone have a suggestions. Everything ewlse seems fine. I dug up an old carb at the wreckers and got the air screw from it. Will give it a go.
Thanks Mike
Posted by: zoommx
On the seals, if you can remove the old ones and read the size from the sides, you can then check with a bearing distributor to get a replacement. You may end up getting seals 1 or 2 mm smaller or larger in width that will still work. As long as they're the right i.d. and o.d. for a rotating application. Just talk to the salesman about the application, they'll know what to get.
Without removing the seals to get size, measure the shaft and case where the seal press fits for the diameters.
vBulletin Copyright ©2000 - 2008, Jelsoft Enterprises Limited.
vB Easy Archive Final ©2000 - 2008 - Created by Stefan "Xenon" Kaeser
