Originally posted by Rich Rohrich: running a high dose of ignition accelerator . |
Originally posted by Rich Rohrich: Just so the "More oil is Bad 50:1 Club" is clear on things, Plug D is from an RM150 running 18:1 and ridden by a complete motosquid (ME) on a really tight track that sees very little WOT running. |
Originally posted by MikeS: Rich Can you comment on "race fuel is dry"? |
Originally posted by Rich Rohrich: DAVE DAVE DAVE, you're comparing apples to porcupines. There is no reason to run 927 in a bike that plonks through the woods, and even I wouldn't run 18:1 in that situation, regardless of the oil. It just isn't necessary. With the correct jetting Yamalube would probably fair pretty well but it still wouldn't be necessary to run 18:1 in the woods. There are lots of oils that lubricate well, but have poor combustion characteristics, so there's little doubt you could find oils that don't run well at low ratios. The trick is matching the loads to the volume and type of oil. I'm not sure if your success running 66:1 says more about oil ratios, or how hard you ride http://dirtrider.net/ubb2/biggrin.gif http://dirtrider.net/ubb2/smile.gif |
Originally posted by Dave Dude: Happy Turkey Day Rich! |
Originally posted by ricky1 Rich, pictures are great, but I was not able to find the text. I looked on your thumper site and Eric's site but no luck. Am I missing something, or is it not up yet? |
