Fuel storage in metal tanks
Posted by: Jim Crenca
Hey Rich,
I've read some threads on storing fuel in metal tanks as opposed to plastic as I assume some of that magic mojo of gasoline must be affected by air getting in. What about the raw fuel from gas stations; they have changed all the tanks in our area to fiberglass over the last 5 to 10 years? Or, is it more of a function of fiberglass vs. polyurethane? Good luck on the job hunt!
Posted by: spanky250
The trick to getting good gas from a station is to find a station that does a high volume of business, so that they have to re-supply the gas frequently. The metal can helps to prevent evaporation, so the more volatile components of gasoline don't simply dissapear into thin air. These components will leach right through a plastic can. This is partly why graphics come off the tank of your bike, the fuel vapors are going through the plastic tank.
1992 KDX 250-FMF porting,two-stage power reeds, Fatty pipe, Power Core silencer,titanium rod,Wiseco Ultra-lite, Pro-Action suspension...Oh my Gawd, they killed Kenny!
Posted by: Rich Rohrich
Teflon and some nylon mixes won't let fuel vapors pass through them, so there is a good chance those fiberglass tanks are lined with something.
"Wisdom is not a product of schooling but of the life-long attempt to acquire it."
- Albert Einstein
Posted by: TM-Frank
I was told that automobile plastic-fueltanks have a fluor-coating on the inside, which works as a vapor stop.
Frank
