Anyone try a Arai MXC pro helmet?
Posted by: Ramski
I've been wanting to try one out since it has the removable face protector. I wear eye glasses under my goggles and find it a pain when removing my goggles since my current AXO helmet has the face protector so close to the face. It seems the Arai is angled further down and away from the face to make donning goggles easier. I already know they are first rate helmets. I would have to mail order since no dealer in my area carries the MXC pro. Thanks for any inputs on this helmet
Posted by: SFO
I have been wearing these for years and just bought a new one.
Try it on first.
I believe Arai has changed the fit on the new MXC.
I noticed the forehead area is tight on my new one where a large used to be perfect.
Maybe my head grew?
Posted by: KiwiBird
5 star helmet, my all time favourite.
Posted by: BikeDstroyer
Ramski,
There is a place called The Helmet Harbor in Gilbert, AZ that carries these helmets at a pretty good price. www.helmetharbor.com I am due for another one and am going to stick with the Arai MXC pro.
Posted by: lawman
i love mine, & the adjustable chin bar is 1 of the things i like about it.
Posted by: Camstyn
SFO, I found the exact same thing with the new VX-Pro. I bought a new Shoei VFX-R and an Arai VX-Pro at the same time, as it was the only way I was going to be able to make a direct comparison.
The Arai felt roomier (and nicer) inside, except that the forehead was too tight for my comfort. The Shoei fit great with the exception that it was tight around the bottom making it more difficult to pull on/off of my head, but I could live with that. I kept the Shoei and sold the Arai.
If it weren't for the tight forehead I would have definitely kept the Arai.
Posted by: SFO
Quote:
Originally posted by Cam Mitchell
SFO, I found the exact same thing with the new VX-Pro. .
Thank goodness!
I thought the proverbial horn was finaly growing out of my forehead.
I will try to push the padding around to get it not to be tight there.
I would still rather fight than switch.
Posted by: KiwiBird
Use a ballpeen hammer to put dents in the polystyrene to alleviate any pressure points caused by forehead horns.
If the pads are too tight around the chin/mouth you can compress them by squashing them and sewing through the pads.
Posted by: CanadianRidr
Kiwi doesn't that wreck the helmet at all? Or it's absorbtion qualities?
Posted by: KiwiBird
Just dent it a little bit - the helmet should fit properly before you start fine tuning it. Some of us got dropped on our heads as kids and have bumps where no bumps should be.
Posted by: Camstyn
For me it felt like the helmet's shell did not go far enough forward, it tapers down too far back at the forehead area, pressing against my forehead pretty much all the way across. I don't think it was the liner, either. Maybe spending so much time in DRN just made by brain expand..
Look, something shiny, over there.....
