Originally posted by MikeS Info on stroking A few questions |
Originally posted by dklink2000 Uh, sounds like a personal problem.
| Rather than bore the cases, TMR grinds the outside of the connecting rod, I'm not crazy about that idea because it has to weaken a shot-peened connecting rod. |
Originally posted by wfo74 I will show my ignorance; but I ask the question; what mods must be done to the cases and/or con-rod to accomodate the 3.2MM? Surely they will interfere. Someone please enlighten an ignorant old man. |
Originally posted by wfo74 Mike; My concerns are that; as the rod must rotate 1.6mm further out on the crank; wouldn't the rod and crankcases interfere? If the stock rod is used, and the cases are not modified, them there must be room, but I have my doubts, therefore my question. I am interested in how the cases would be modified, as there can't be much "meat" in the cases. |
vBulletin Copyright ©2000 - 2008,
vB Easy Archive Final ©2000 - 2008
