xr 650 r
Posted by: Mr Xr
rs-3 yoshi race pipe had 3 lead pipes replaced ; all cracked at mounting bracket any one else had same problem and how to fix or are they just ****
Posted by: penguin
The Honda race team has had problems with the pipe cracking at the mounting brackets from vibration. I believe they ended up using a pipe mount off of a Honda ATC250R to fix the problems. I will look in my notes from when I owned a 650R and see if I can come up with a part #.
Posted by: Redrider
just curious.....I have a 2002 xr 650 with power up kit(jets, baffles removed, exhaust tip, manifold) which starts like a dream when cold. First or second kick every time. when the bike gets hot though it is a bitch to start. Runs fine after it starts. What could be the problem.
Thanks Redrider.
Posted by: penguin
check the valve adjustment or a too lean pilot jet
vBulletin Copyright ©2000 - 2008,
vB Easy Archive Final ©2000 - 2008
