Goggles with Nose coverage?
Posted by: NVR FNSH
I wear contacts & currently use Smith Violator goggles with a roll off system. These are the frames that have a 'bridge' over the nose, sweat diverter and multiple desity foam filters for various conditions. I've been using this pair for several years and it's time to replace them as the frame is starting to come apart. Are there any other goggles out there that you can recommend I check out before buying another pair of violators? I really like the nose coverage because it seems everytime I wear my spare goggles w/o the nose coverage I get thumped on the nose with a branch or somebody's roost.
Thanks,
Brian
Posted by: Timr
I went through the same thing you're going through.  In the end, I ended up buying another pair of Smith Violators.
Good luck!
Posted by: MTRIDER
Pro grip ....Best goggles I;ve found. With all the features you mentioned above.
