need help with finding a math formula
Posted by: jmics19067
I would like to get more wattage out of my stock lighting coil. I do have the mechanical space to make the coil approximately 50% bigger by "stacking the plates" but I have no clue on how the amount of coils ,length of wire in the magnetic field or wire size affects everything.
I am hoping someone could give me a link to a website or know of a book in a library that would have an excellent tutorial on how I can figure this out myself. Everything I have I found on my own was either too simplified with no detail or too specific for 3 phase motors with no tutorial for an average Joe.
If I can find a formula that tells me what is doing what where, I am thinking of taking this formula and running it backwards,ie knowing what I have now for stock output at a given rpm ,disassembling the coil ,counting the wraps and measuring the length and thickness of the wire ,I can figure out the "Henrys"< I believe that is the proper term for magnetic field measuring>.
I then hopefully take my figure of magnetic field measurement and run it thru the equation with a few different options of variables to try and get decent output. Once I understand the formulas would this be a proper plan of attack ?
Posted by: biglou
Here's a thread from about a year ago with a couple links in it to some good sites. Hope it's useful.http://www.dirtrider.net/forums3/sh...eferrerid=19516
thanks Lou didnt have too much time to track down all the links right now in the thread but it made for great reading. It definately helped clear up what I believed I knew , when I chase down the links I should be able to draw up some concrete ideas!!!!!!
