| This would allow for slightly less ignition advance and consequently more DETO resistant by reducing the time deto could take place |
| allow one to advance spark timing closer to TDC. |
Originally posted by Sean Hilbert Faster burn will create higher peak cylinder pressures, however, and the engine can become noticeably rougher (i.e. like a diesel). |
| heat transfer between a moving gas and a solid (i.e. convective heat transfer) is directly proportional to the velocity of the moving gasses across the surface. |
| Would reducing the ignition advance help with the rougher running by moving the time of the peak cylinder pressure closer to optimum? |
Originally posted by Sean Hilbert Think, design, cut, test...and do it over again... |
sorry I heard that on another sight and thought Id pass it along.
vBulletin Copyright ©2000 - 2008,
vB Easy Archive Final ©2000 - 2008
