iCAT
Posted by: dbrace
Just wondering if any of you guys have heard of an iCAT ? They plug into the high tension lead between the spark plug cap and the coil. The results are impressive.
Posted by: buffmaster
Do you have a webpage for them or something? I did a google search and came up w/nada.
Posted by: wibby
Hmmmm
I did a google search and found this: http://www.icatsportusa.com/technical.html
Posted by: dbrace
Has anyone heard of these things? They plug into the high tension lead between the plug cap and the coil. The power gains are impressive.
Posted by: turboandy
I would like to see what the dyno says about the gains.
Posted by: Swiss
I believe that you are talking about the device on this website http://www.motiv-icat.com/
Basically they are talking about improving the ignition by reconfiguring the ignition pulse shape. This MAY help in some lesser ignition systems, but could be considered questionable if compared to a good ignition system. It is mentioned that it "allows" COMPLETE" burning of the fuel mix, this is doubtful, regardless of its effectiveness. There is a lot more involved than just a simple pulse/wave ignition design on whether your charge burns anywhere near completely or not. Nice advertising hype though. Would probably be better off with some of the 'Nology products. Yes, they have also been shown to give some performance boost.
Swiss
