I would have like to have seen it.
) will be much more enlightening than any pics.
Originally Posted by tjswigger
Is it possible to create some kind of catalytic converter to further clean the 2-stroke exhaust? I've never heard of any such device.
| I think that Aprilia has fitted a Catalytic converter to a two stroke scooter. |
Originally Posted by Doc
I really can't talk about the bike anymore.
I have heard that GasGas is working with Magneti-Marelli on a DI bike. I'll let you know if I see anything DI at Intermot. Doc |
Originally Posted by Rich Rohrich
Hey Doc - I tried to read the two JSAE papers you authored with the guys from BRP.
Originally Posted by LJW
Rich,
Care to pass on the names and numbers of these papers? |
The papers are (I can provide copies of these or you can get them at SAE.org):
"Optimization of the E-TEC Combustion System for Direct-Injected Two-Stroke Engines Toward 3-Star Emissions" "A Method to Determine Total PM Emissions from Marine Outboard Engines" "Modeling of Scavenging and Plugging in a Twin-Cylinder Two-Stroke Engine using CFD" "Modeling of Air-Fuel Mixing in a Two-Stroke Direct Injection Engine" Cheers, Doc |
, gonna be working at ROTAX that week. I wish the World Supermoto race in Austria had not been cancelled, I wanna see one of those.
Baro compensation is handled by a compensation map and the ECU uses a baro sensor.
True, SDI snow machines meet the 2006 EPA rule for snow machines, but the 2006 EPA rule for bikes is much more strengent,~ by a factor of 10.
Doc |
Originally Posted by dkinaev
Why did it take companies all of these years to squash an injector in instead of a carby when my turbo Nissan Silvia has been using this technology since 88? Is it really the weight difference?
-Dmitri. |
Also how tunalble will these CPU's be. Most car companies DO NOT want people to screw with their CPUs. I know that for example for my engine, (ca18det) I need to get the cpu, take out a flash chip, remap it while on the dyno then stick it in.) Sure there are aftermarket "high performance chips" for like 1000 AUD! When the actual price of the chips in the the cents. Will these DI manufacturers be heading the same way with motorbikes that are now "untunable" by the average person? Will putting a new pipe need a trip to a shop with a dyno?
?? -regards -Dmitri. |
Sorry guys, but I really can't talk about it.
Doc |
A nice light woods weapon that can go 80 miles on a mx size tank.
Doc |
Besides I'd give anything for a 2004 version DFI RZ350 or RG500 ![]() |
I'll see if I can get in touch with Doc and find out if it's possible to give us any updates.
vBulletin Copyright ©2000 - 2008,
vB Easy Archive Final ©2000 - 2008
