Originally Posted by sdm
I agree with everyone above in that we need more info. Some things to eliminate
in addition to what has been mentioned above are. 1. make sure you are using fresh premix 2. make sure the air filter is clean and also the fuel filter (if it has one) 3. install a fresh spark plug Something to think about might be that if the slide is worn to the point of being loose, the needle jet and needle itself may be worn also and causing an overly rich issue. The pilot jet could also be plugged.. These things might be some places to start anyway. Hope this helps Sam |
