Buying protaper handlebar do I need a pro taper throttle tube?
Posted by: mazeco
Buying protaper handlebar do I need a pro taper throttle tube? Also does the handlebar fit well with the oversized bar mount kit? It's gonna go to an 04 yz250f! Thanks
Posted by: Dirtman500
No need to buy any items other than mounting kit. Unless you are installing Barkbusters. Barkbusters require clamp kit.
Posted by: joereitman
My Protapers fit real well with the MX Bonz mount kit. From MXSouth.com. $80 for Bars, $50 for mount. Rode hard yesterday, very satisfied.
Posted by: n8MX
The Protapers taper down to 7/8" on the ends so that the stock throttle and levers will fit. As I'm sure you have heard, the Protapers are great bars - a couple months ago I was trail riding and ran into a power pole in 3rd gear... the bars (brake master cyl) hit first and there is no visible sign of anything wrong (not bent) - that crash somehow completely trashed my pipe, forunately I was OK...
Posted by: jackdrinker
my bike has the tag t2 privateer kit that includes the upper
t-clamp. includes grips....
