Originally Posted by mxneagle
Actually I thought MC DNF'd because the bars were too strong and actually broke the triple clamp instead.
Originally Posted by KXaggerator
I had a high speed get off in the desert on my KX500 that bent one bolt and sheared the other off of my Applied bar clamp, but I still run those same Protapers five years later with no apparent damage to them. Now if they would just make a Jimmy Button bend I would be even happier.
, My tag bars on the other hand bent my first crash and i had to get a new set of pro-tapers for my crf450
Will,
I am just over 6', but I am tall in the torso. I have the Button 7/8" Renthal on my KX310 and nothing feels better on any bike I have ridden and the cross bar just clears my GPR steering stabilizer. Here is the goon like specs: A - 807 B - 110 C - 85 D - 205 E - 67 |
Originally Posted by yz250roost
Hey guys,
I just wanted to warn all of you Renthal Twinwall users to check your bars as soon as possible. The Twinwalls seem to be cracking on the larger bar, right at the bend above the crossbar clamp, it will most likely on the side facing the rider. I have seen lots of these bars coming in over the last two months, and most of the cracks are very small hairline cracks that you wouldn't notice right away, you have to really examine the bar. If you find that your bar is cracking please send it to Renthal America as soon as possible for a replacement. Jeff |
. I need to order new bars now and after riding a 04 KX 250 I seem to really like that stock KX bend. What I need to know is if KX bend bars are the same as 04 spec??
Originally Posted by Shocknut
In this instance I will withdraw my comment of not ever buying Renthal TwinWall bars again. Although I had 3 of them crack I never had a problem with them beyond that. I didn't know that the crack was no big deal, but I can say that after noticing the crack on my 3rd bar I rode most of the rest of the season with it as it was.
I felt I would never be able to destroy my Azonic DoubleCross bars. I did it last Thursday at Cooperland though . I need to order new bars now and after riding a 04 KX 250 I seem to really like that stock KX bend. What I need to know is if KX bend bars are the same as 04 spec?? |
