01 WP USD 43 fork disassembly procedures?
In need of specs and procedures in order to change my fork seals, 600 miles and leaking seals already.
Any help greatly appreciated.
Thanks in advance.
This seems to be a common fault?
Tom
If you have never done anything like this before, I would recommend a WP service manual. There are some very important steps that you must take when reassembling i.e oil levels, bleeding the rebound, and compression and rebound nuts.
WP Service manual, sounds like what I need, do you have part numbers and would you expect I'd be able to get these thru KTM dealers?
All I need is to be able to replace the fork seals. I can change the fluid, spring and spring preload.
Just the next step.
Thanks in advance
[This message has been edited by KTM400EXC#232 (edited 04-09-2001).]
- a d v e r t i s e m e n t -
