1967 Triumph TR6C Rebuild by a noob.
Super Power AssClown
#46
You will need the clutch hub puller to get the clutch off. Part # 61-7014. I can have one shipped to you if you want. Be sure to loosen all of the nuts before taking anything else apart. (Clutch nut, engine sprocket nut, pinion and cam gear nuts.) Cam gear nuts are reverse thead. May I suggest you download a parts book for your year model. The exploded view in the parts book will help you see how they go back together. You can download one at www.britishonly.com/technical.library. British only has their parts department closed for an extended vacation right now but you should still be able to access the tech library.
Without the puller you can take the clutch apart piece by piece but the last piece is very fragile and will break using a regular gear puller. Best to have the OEM puller.
Location
Dallas
#47
Cool thanks. I’ve already got the parts books and shop manuals , and I *thnk* the clutch hub puller. I’ll let you know.
Cant get to that tech library.
Are you saying to loosen everything before pulling the motor? Ie; it’ll be easier with it bolted down?
#48
Yes, loosen everything first. I will see if I can find another link for the tech library. The puller in your pic (Center front) looks like the clutch hub puller.
Location
Dallas
#49
Alright... that's as far as I can go without the clutch plate tool and the primary puller. Stator/rotor are off, clutch is apart but the basket is still there.
I'll probably pause here until after the holidays. There's plenty to keep me busy until then just cleaning stuff.
Likes: truespode
#50
You can make the clutch holding tool by welding or bolting a friction plate and a steel plate together. Or weld a handle on to the steel plate to hold on to. You will probably need to replace the friction plates anyway and a steel plate doesn't cost much. Be sure to surface your steel plates using a piece of emery sand paper and a flat surface. Like glass.
Likes: Okiewan
Location
Dallas
#51
Not a great day!
Started cleaning it up for disassembly...
I discovered a case repair on the primary side. Looks like the primary chain must have slapped/snapped or something?? It doesn't look to be from wear (loose chain), there was def. impact of some kind. Broke a piece of the casting inside by what appears to be an oil outlet just above the clutch (hole is still there and appears unaffected.
From the outside I noticed the piece welded in due to the difference in surface texture. Inside the bead is obvious. Looks like they did a good job, but...
So then, I'm looking over everything closely, and I find a hairline crack in the case above the drive sprocket. I'll attach pics of each. Since it's near the other damage, I guess it could be from the same problem, but no idea.
I cleaned and went over the frame today as well... didn't find anything, but will go over it in more detail tomorrow.
I'll go ahead and assume this will kill collectible value. The question is, should I continue with the rebuild or just check / replace the trap and put it back together?
That sure took the wind out of my sails!
Pic #1 . welds / inside casing damage
Pic #2 Hairline crack above drive sprocket.
Pic #3 location of crack for ref.
Likes: truespode
#52
Not a great day!
It's your lucky day. I can fix that for you. It's one of the things I do in my shop. The photo below shows a few other tools I use. #2 is a home made tool for removing and installing the clutch springs. If you have the tool kits with the bikes you should have tool #1. It is a tire tool and also a clutch spring tool on the other end. #3 is a homemade tool for removing the screwed plug that holds the sludge tube in. If you make one, make sure it fits the screwdriver slot tightly and use an impact driver to remove it. #4 is a 9/16 X 18 tap used to remove the sludge tube. I drop a short piece of rod(#5) into the sludge tube (#6) and run the tap down the tube. The rod bottoms out and draws the sludge tube out of the crank. Be sure to drill out the center punch on the screwed plug and heat the crank before trying to remove the plug. That other tap that I posted in the last tool pic is a 1/2 X 14 NPT used to draw out the camshaft bushings on the L/S case. Are we having fun yet???
Likes: truespode
Location
Dallas
#53
Sweet... I'll get that casting off to you asap.
Edit #1 Dec 12, 2019
FYI: ol'89r advises that he can fix the case; the hairline crack, clean-up the welds inside as well as re-texture the outside of the case to match the original surface. I had no idea that could be done and was bumming about the the area having been sanded smooth and making the repair obvious. Yes!
What did this begin life as?
#1 & #2 ... I have a tool for the clutch springs.
So the sludge tube has no bottom? I'm not getting how it backs-out otherwise ... the tap pushes the rod, and pulls the tube as it's cutting threads/screwing in, but unless the rod is against the crank itself (ie; hole in the bottom of the sludge tube) I don't get how it's pushing the tube out?... looks like my noobness is showing. I'll cross that bridge when I get there.
Likes: truespode
#54
#3 was a 1/2" to 3/8" adapter ground down to form a screwdriver to fit the slot in the plug. It has to fit tightly. The sludge tube is open on the other end. When you screw the tap in, it pushes against the rod and the rod pushes against the crank and draws the sludge tube out. Be sure to remove the flywheel bolt that holds the sludge tube in. I will send you my address in the Mod forum so you can ship the cases.
Likes: truespode
Location
Dallas
#55
Thanks for that Terry ... I assumed the sludge tube was only open on one end. I've seen a few videos on this now and the method you describe here makes the most sense.
Likes: truespode
Location
Dallas
#56
Update. The TR6C Mystery.
I've got serious reservations that this '67 TR6C is the same bike as the one he bought (or remembers buying) in '69. I asked him (84 year-old previous owner) about the damage on the primary side, assuming it happened sometime when he owned it. He remembers nothing about it. Also, he had mentioned previously that he never had the top-end or any major engine work done on it. Obviously he's confused as this cylinder has been bored .060. I guess that could have been done (damage and top-end) within the bike's first two years, but I kind of doubt it. He bought a '67 in 1969. I'm just not sure if it was THIS '67.
Having owned 9-10 Triumphs over the last 40+ years and memory that isn't great, it very well may be that he's confusing the specific history of his bikes. It's not the end of the world by any stretch, I just don't know the history of the bike like I thought I did.
Likes: truespode
Location
Dallas
#60
Kinda stuck at the moment... waiting on the clutch hub puller I had to order so I can finish the primary side disassembly. I can't wait to get these cases split and get a look at the crank... fingers crossed that the journals look good and that the sludge tube isn't a huge pain to get out.
After figuring out what all I need (the tap and the slotted socket alone will be close to $50 and I wouldn't trust my smallish vice to secure the crank) to replace the sludge tube, I'm going to find out what Big D Cycle will charge if I bring them the crank. I'm already taking them the jugs, might as well see what they'd charge to do the trap.
Yeah, I know. :$
Likes: truespode
