bill bowring
My 1974 Yamaha DT360 has a oil leak from the clutch arm pivot shaft on the left side under engine . I need to pull the shaft out to replace the seal. The parts diagram shows a return spring- washer- seal- the only thing I can see that mite hold the shaft in is the clutch adjusting screw. I thought if I loosen the lock nut and back out the adjuster the shaft mite slide out . Have any dt360 owners had any experance replacing this seal ???? Thanks advance for any help. Bill B
