May 22, 2007
I finally got my bike running good,But I wrecked due to some big mud ruts at our local track the other day.When I got up there was a lot of gear oil leaking from the middle of the case.It appears to have some sort of drain hole or something but I'm not sure if there should be a plug in it.Is there suppost to be a drain hole on the top/middle of the gear case? Also its leaking oil near the kickstarter.Can I just replace the seal and it will be fixed?
XR250rdr
95
Yes there is a drain bolt for the gearbox and yes you should be able to fix the seal and be good to go. Do yourself a favor and inspect the side cover while you're at it. The coolant tends to eat the cover after a while.
2strokerfun
1,500
The kickstarter seal is also easy to replace. Put some grease on it before you slide it in. Hopefully, it will stop the leak, if your kickstart shaft is in good shape.
