Cowboy0710
Hey guys I have a 1990 Honda Cr125R 2 stroke and it seems like it isn’t getting enough fuel. It bogs out and I’ve tryed adjusting the idle and the air and cleaning the carb but it is still bogging out. Any advise??
jaguar
1,503
82
South America
check for air leaks at the left crank seal, frayed reeds, bad head gasket, clogged air filter, clogged silencer, and replace the spark plug. Then take out the jets in the carburetor and run a wire through them to clean them out. Also clean off the residue sticking to the float bowl. Also check the piston ring end gap and replace them if too much. Spray carb cleaner into the air holes at the entrance to the carb.
