1994 CR250 cylinder swap
Discussion in 'Bike Mods, Performance, Maintenance & Repair' started by ash, Jun 18, 2002.
  1. ash
    ash Rookie DRN Member
    Jun 18, 2002
    Hi, I read on Eric Gorr's website where all CR250's from '92-'00 have interchangeable cylinders. A friend of mine has a 94 CR250 with a cracked cylinder from the sub exhaust port to the main one, so we were wondering if we could fit the 1999 CR250 cylinder but still use the 1994 CR250 piston (he bought a new piston kit before we knew the cylinder was cracked). The reason I ask is that Honda have different part numbers for the pistons so I thought deck height and skirt length might be different.
    Cheers,
    Ash
  2. EricGorr
    EricGorr Super Power AssClown
    Aug 24, 2000
    790
    Yes the 99 will fit and it will have a better trail riding powerband. All the CR250 cylinder from 1992 to 2001 have the same overall length, the powervalves and studs fit the same way too. The only thing to remember is to match the pistons and heads. The 1992 to 1996 have domed pistons, and heads with angled spark plugs and the 1997 and later have flat top pistons with a centered spark plug.
    Honda cast the insides of the cylinders different for various powerbands. Heres a quick run down on the models.
    1992 The biggest ports ever! Problems with reliability though with quick piston wear and cylinder skirt breakage. For DTX and karting, the 92 is the best.
    1993-95 The intake port is smaller to reduce piston wear but the exhaust was still rather large.
    1996 The perfect off-road porting, good reliability too.
    1997-98 A screamer with the sub exhausts raised and widened, low to mid range was a problem.
    1999-2000 Honda rebounded a bit too far by detuning the cylinder and shrouding the Boyesen ports and retarding the porting.
    2001 Honda rebounds again this time advacing the timing so only RC could handle it. However this cylinder has great structural integrity with massive skirting.
    Good thing Honda lost the plans for the 1996 cylinder or I'd be out of business :whiner:
Similar Threads: 1994 CR250
Forum Title Date
Bike Mods, Performance, Maintenance & Repair 1994 Cr250 Apr 3, 2005
Bike Mods, Performance, Maintenance & Repair 1994 CR250, New To Me Sep 28, 2004
Bike Mods, Performance, Maintenance & Repair 1994 kx125 sprocket Question Mar 4, 2009
Bike Mods, Performance, Maintenance & Repair 1994 kx125 Dies after 10 minutes or so of riding Sep 19, 2008
Bike Mods, Performance, Maintenance & Repair 1994 kawasaki kx125 Dec 19, 2007
Share This Page
