2000 cylinder on a 1995 yz 125
I just bought a yz 125 that has a 2000 cylinder on it with a 1995 piston in it. My problem is I can't get this thing to start.It has good compression,spark ,fuel, and looks like proper timing.It acts like its going to hit and start but will not.
Eric or Rich I know you guys are the best.Do I have to run a newer piston with boost port to run with the 1038 bearing ?
I am lost on this thing please help
i think the piston is the problem, i believe the 2000 piston has an intake window and the 95 piston does not
Eric Gorr
Engine Builder
#3
The piston window won't hinder the starting unless the piston is backwards. The rectangular window should face the intake side of the cylinder.
