I just picked up the bike. It starts fine but idles high. I messed with what I thought was the idle adjustment screw and it dies. <-has no effect on idle until turned all the way out then it dies.) Fould the plug. I pulled it cleaned it and put it back in. I think I flooded it as well. Finally started. seemed to run fine. Then after about 5 min it started surging very lightly but it was surging then it started to bog and die.
I did notice when I was draining the gas to check the filter the gas would slow down until I cracked the cap.
Checked the throttle cable and its not making a difference.
Also when I rev it up the idle hangs until I kick it in gear.
