shock low speed compression(center adjuster) 12 +/- 2 clicks
high speed compression(big nut around center adjust) count or mark the nut-close all the way,then open all the way while counting the mark,then "tighten" approx half way-this will be a starting point as is all settings
rebound(lower register) 20
all adjustments are from fully closed,then backed out except for the high speed on the shock.These are the stock settings,adjust accordingly.Good luck.
