80 ke175 sticky gears
So I picked up an 80 Kawasaki ke175, no clue how long it hasnt been running, and finally got it going with a carb rebuild. The thing runs good and shifts pretty good from 1 N 2. It does not want to kick up into 3 4 or 5 when running. I pulled the clutch, deglazed the plates and checked it all over. It has 1 broken tine on the each of the outer 2 friction plates but otherwise in good working order. I took it for a trail ride today and was able to powershift into 3 4 and 5 if i leaned over and yanked up on the shifter. The bike does not travel through the gears well tho and I had to stop and shift from 3rd to 2nd by hand. It seemed to free up the more i forced it through the gears but is still very sticky. Is feels like the shift drum is sticking but I dont want to pull the motor if I dont have to. Any tricks to freeing up the tranny?
Likes: Okiewan
Location
It's sounds like something is worn or bent but you won't hurt anything trying different types of trans oils.
Motorcycle transmissions can be fickle , so it might take trying a few until you find one that your bike really likes. Dexron ATF is an excellent starting point, given that automatic transmissions in cars share a lot of the same characteristics as the wet clutch transmissions we have in bikes. A high quality 10W40 automotive engine oil will also work well in a lot of cases. There are lots of great options. I've run Shell Rotella 10w30 in lots of transmissions over the years with great success.
Likes: Okiewan
I run Valvoline motorcycle oil in all my bikes. It works well for me. I think I'll mash em for the rest of this season and pull the motor when the snow flies. Something feels bent.
Well, I guess there was a collection of gunk in the motor. Changed the oil again after a good power shifting run and the next day it shifted waaaay better. Still not very smooth but I can go up and down the gears now. Onto the wiring mess now!
Likes: Okiewan
- a d v e r t i s e m e n t -
