i have had problems with this bike since i owned it. i does not do this all the time but most of the time it does. well you really get on the gas from idle it makes the boo-wahh noise and tries to stall. i have been doing my best to try to figure out the problem, i took it to a local shop and the bike sat there for a month only to have them tell me it was a bad ground for the cdi but that didnt fix it. ihave been trying to do my own reaserch on this problem using the internet and im stumped. my bike seems to blow a lot of oil out the exhaust, i has a newer top end, i mix the gas at 32:1 with klotz oil, it has a fmf fatty pipe on it and i have stock jetting according to what the service manual calls for. i have found some info about this but they said it is from a lean condition, but how do you explain the excessive amount of oil blowing out the exhaust, i also read about a possible crank seal on the clutch side being bad and the oil is being drawn into the engine and being burnt, but the bottom end of the motor was rebuilt at the same time as the top end and the oil in the transmission is never low and is its normal color. i seriously dont know what to do, could it possibly be jetting? also the shop i took the bike checked out the electrical stuff and they said it was ok other that the bad ground. the bike runs bad 8 out of 10 times i ride, it seems to change with the weather too. if anyone is interested in helping me figure this out once and for all, it would be greatly appriciated.
