KTMDan
31
Anybody willing to share some jetting setups with me? I ride a 98' 380 MXC in elevations from 3000 to 7000. I currently have an FMF Gnarly pipe with stock silencer. Any comments will be welecomed!
jeb
633
Here's the specs I ran on my 98 380MXC. 50 pilot, 1.5 out on the airscrew, the stock slide, a 170 main, and an R1467N needle (most critical part) in the middle position. It's a Honda needle. The Keihin part number for this needle is DGH.
Seems odd to move up the pilot to a 50 but trust me, it works. This was at about 1000', stock exhaust, 40:1 Y2R with 92 pump premium. I went to a 175 main when I put an FMF pipe and TCII silencer on. I'm not sure what the elevation will do to the jetting but I'd still think this would be a good spec to start with, at least.
Setting the bike to barely idle helps get rid of the spooge, too. I had ZERO spooge with this setup on both exhaust systems.
This setting has been used and approved by several other 98/99/00 380 owners.
Strick
1,782
KTM jetting is altitude and temperature specific. I ride at 4500' to 7000' during all seasons, except summer. In the hot months we head real high up, 9000' max.
Here is the set-up for our altitude:
#7 slide
45 pilot
170 main
1369N needle (#3clip)
A 50/50 race gas/pump gas mix really makes the bike perform better (especially in the winter)
Strick '99 KTM 300mxc, AMA & BRC member
KTMDan
31
Strick, your setup sounds pretty rich. I realize that tempetures play a huge role in jetting. The temps up here range from 40 - 85 in the summer during our rides. Don't these bikes come stock with a 175 main? The slide #7, I assume you mean a 7 degree cut? Is this leaner or richer than my stock 6?
What temps are you running at. Right now I have a 160 main, 45 pilot with stock needle and stock slide, needle is NOZG??
Strick
1,782
Single taper needles in conjunction with the #7 slide, mandate the use of richer main jets. #6 vs #7 is in reference to the cutaway portion the #7 has 1mm more cut out of the cutaway portion of the slide. This yields a leaner condition.
Desert Guy
7
Boy what a variation in jetting. I've spent alot of time jetting my Y2K 380 EXC for 500-1000 feet altitude along the Colorado River with high temperatures. My plug is perfectly tan colored, and I run a #7 slide, 180-182 main, 40 pilot, and a CEK (1369N) needle. When I try and run a smaller main my bike doesn't rev out. My responce off the bottom is awsome as is the entire range with this setup.
Buckholz
396
Had a '98 380. Now have a 2000 380. Dropped float level a tad on both, as carbs angle down and engines tend to run a little rich. The 2000's and later come with a jetting guide. It has worked perfect for me and two other A riders on our 300's and 380's. We run 40:1 with premium fuel - 92 octane. One of our three bikes has 3200 miles on it with one piston. We don't foul plugs....
Get with a buddy to get the chart or I'll email you one....
Buckholz
396
Forgot to mention that all three of us live at 7,000', and ride from sea level in AZ to the 10,000+' passes of CO.
KTMDan
31
Buck,
I would appreciate it if you could email any jetting charts you have. leclerc@centurytel.net
Montana300
123
I suggest you richen your main jet for the cold temps we are currently experiencing during our rides. I will try and locate my main jet tool so we can try a few combinations tomorrow.
