99 yz250 needle removal (dumb question)
YamaB
401
Ok, I took my carb apart, but I can't figure out how to get the needle out. I removed the throttle slide, spring, and throttle cable. There is still that silver thing (holder) left. I cannot figure out how to remove it... It doesn't seem to want to pull or twist out... Granted I'm applying fairly minimal force (don't want to break it)...
So how do I remove this doohickie so I can get at my jet needle??
thanks,
Brian
YamaB
401
I guess it would make more sense for it to unscrew... Considering the throttle cable pulls on it to lift the slide, it wouldn't make much sense for it to pull out...
- BA
Brian
Stanbagger
1,452
It takes a 6mm nut driver. Just be careful not to cross-thread the nut when re-installing it. Those small threads can get buggared up very easily.
