Apollo 125cc gas in oil
I have an Apollo 125cc dirt bike. There is gas in my oil and a friend told me that I need to drain the old oil, put in new oil, crank it a few times and then drain it. Then after all that I can put in oil and it’s okay. Just want to double check with other people that that is what I should do. Thanks
Location
It's a good place to start, but eventually you'll need to find out how gas got in the oil in the first place. It's worth checking the float level on the carb to make sure it isn't set too high and leaking gas into the crankcase. You might also want to verify that the gas valve on the tank shuts OFF completely.
Likes: Okiewan
