Big Bore kit for 2001 CR 80 Expert (103cc)
Discussion in 'Bike Mods, Performance, Maintenance & Repair' started by KawiRider, Aug 30, 2001.
  1. KawiRider
    KawiRider Rookie DRN Member
    Sep 23, 2000
    173
    How is this? Does this affect the motor? Does it make it unrealiable? Please post if you know of anything.
    -Thanks
  2. IBWFO
    IBWFO Rookie DRN Member
    Aug 5, 2001
    367
    Sure it makes it LESS reliable, because you are taking what is meant to be an 80 and punching it out to 103. Beware, the really good shops that do this will ask you to buy the piston and send both the cylinder AND the piston to them.
    If done right the bike will "rip"!
    Regards
  3. EricGorr
    EricGorr Super Power AssClown
    Aug 24, 2000
    790
    Hi guys,
    The reliability issue of increasing the bore size is related to these issues;
    1) The compression ratio
    2) The width of the exhaust port as a percentage of the bore
    3) The weight difference of the piston
    3) The ratio between the bore size and the pipe's ID in the header
    The trend that I'm seeing is for companies just to bore the cylinder without adjusting the ports, which makes the bike strong on low end but flat up top. Another problem is sloppy port chamfer or the top radius of the cylinder. That can cause ring scuff and head gasket leaks.
    There are several variations of pistons on the market for the CR80, I prefer the 766PS from Wiseco. Its close to the stock piston weight and they make a corresponding gasket kit so you don't have to bare the expense of o-ringing.
    So to wrap it up, increasing the displacement of an engine won't make it unreliable as long as the work is performed carefully and the powerband matched to the riders' needs.:)
  4. KawiRider
    Sep 23, 2000
    173
    Thanks for all of your replies. I am very appreciative of them.
    -Thanks!
Similar Threads: Bore 2001
Forum Title Date
Bike Mods, Performance, Maintenance & Repair 2001 yz 125 big bore question? Jan 16, 2008
Bike Mods, Performance, Maintenance & Repair 2001 Yz250-300 Big Bore Aug 18, 2002
Bike Mods, Performance, Maintenance & Repair Bored & Stroked Jun 23, 2010
Bike Mods, Performance, Maintenance & Repair nikasil bore? Jun 3, 2010
Bike Mods, Performance, Maintenance & Repair Bored out CR 125 blown head gasket Aug 28, 2009
Share This Page
