I have a new KX65 that calls for a 32:1 gas oil mixture. I was looking at the Team Green jetting recommendations and they call for a 40:1 ratio. Their testing specs of 70 deg. and 0-3000asl fall within my same area. So should I change the fuel oil ratio to match theirs? The bike is rich. It smokes pretty much white smoke. I have moved the clip up one position already. It also has pretty much spooge running down the outside of the silencer.
I don't know much about this bike or 2 strokes in general so a little knowledgable help on changing the fuel ratio would be appreciated. Or, should I just stick with the 32:1 and change mainjet and clip position?
They also call for a hotter spark plug, so I would do that at the same time.
I don't want to burn the bike up doing something stupid so please help if you can.
