RECENT POSTS
Help CR125 w/ PWK 38 mid range bog when opening throttle quick
Just swapped my old mikuni out for a pwk38 airstryker. Bike idles perfect and makes great power up top. In the middle of the rev range it bogs out if you twist the throttle wide open and if you hold it long enough it dies. If you slowly rev it out it doesn’t do it. More noticeable in neutral.
Got the carb and jet kit from JD Jetting so I can swap some things out. Would this be to lean of a pilot jet? The kit only came with a 45 and a 55 and the 45 is in there now.
Have a video but not enough posts to paste the link. I can message it if needed
