Fork Bushings?
Discussion in 'Suspension' started by MikeT, Jan 30, 2003.
  1. MikeT
    MikeT Subscriber
    Jan 17, 2001
    4,138
    36
    I've recently head some talk here about checking and replacing fork bushings on Yamahas. I have a 1996 YZ125 and am wondering, how would I know if I need new bushings or not? I looked on the Yamaha of Troy website and I couldn't tell which piece on the fork diagram was the bushing. When I take the tubes apart to change a seal is it easy to replace the bushing then? Are there any special tools needed other than what is needed to replace a fork seal?? How much does a bushing cost and what is the bushings purpose??
  2. marcusgunby
    marcusgunby Lifetime Sponsor
    Jan 9, 2000
    6,590
    Its hard to test the bushes as they have a fair amount of slop from new.If you havnt replaced them before they are overdue.They are easy to replace as when you change the seals you just need to take the old bushes off and replace with new.No more tools than for a seal change.
  3. MikeT
    MikeT Subscriber
    Jan 17, 2001
    4,138
    36
  4. marcusgunby
    Jan 9, 2000
    6,590
    That diagram is terrible, i think its 5,30 i would just ring a dealer and ask them-if you havnt done them for a while it will need dust seals as well.You should notice plusher forks at the top of the stroke.Also worn bushes cause new seals to leak.
Similar Threads: Fork Bushings
Forum Title Date
Suspension 1990 CR 250 fork bushings Mar 21, 2009
Suspension Worn forks or bushings Apr 20, 2006
Suspension Race Tech fork bushings May 31, 2005
Suspension 2000 RM250 fork problems/worn bushings? Apr 5, 2004
Suspension Fork Bushings Dec 30, 2003
Share This Page
