NoChance
Im riding a Suzuki Rm125. I've got a simple question. How many ounces of two stroke oil do you put to each gallon? My moms boyfriend does the whole oil/gas thing and there is hella white smoke coming from my exhaust. So how many oz. to the gallon?
MX-727
1,811
13
Depends on the ratio. The first number in the ratio is the number of ounces of gas. If you want to use 32:1, then you have 32 ounces of gas for every 1 ounce of oil. 40:1 means 40 ounces of gas for each ounce of oil. Now it's simple division. You just need to know how many ounces of gas you have. I'm sure you must know that a quart is 32 ounces and there are 4 quarts in a gallon. That means a gallon is 128 ounces. You can figure the rest. :)
2-Strokes 4-ever
1,842
4
Missouri
32:1 is what your 125 wants and needs.... 4 oz. of quality oil per gallon. Use her measuring cup.
