Gas tank swap?
I recently put a 2001 520MXC tank onto my 2001 520SX. I noticed after the switch that the choke hole is about an inch off. When I turn the choke off I barely catch a corner of it through the hole in the tank. Since I use the choke only once a ride, I’m not really too concerned about it, just a little curious why. Also, the hole lines up perfect with my SX tank on.
Does the carb sit closer to the engine on the SX’s ?
Do all the MXC tanks come factory like this?
knobbiethrower
Lifetime Sponsor
Check the installation of the tank on your bike.Make sure it is seated correctly.It may not be in the two rubber grommets (above the engine)correctly.Did you have to buy a new seat?:D
It does use a differant seat than the SX. (I believe the MXC and EXC seats are the same). I have to get the "Post" that holds the seat to the tank today, but even when I lay the new seat on, it seens as though it will line up perfect. I'm going to ask the dealer about it today when I pick up my new part.
knobbiethrower
Lifetime Sponsor
Good Luck, I have a 2001 520 Sx and I use a EXC tank & seat.It takes some fiddling to get the tank just right on mine.
Tiger
Subscriber
MXC tanks...
Johnny,
I have a 2001 KTM 400 MXC. My choke does not line up "perfectly" either. On an SX you'll need the black radiator grommets (2) that are only found on the MXC lines. It'll make the tank snug fit. Most dealers say they don't exist. You can see them when looking at the front of the bike. Same as the ones found under the tank (On MXC's). Good luck.
Paul
