Hair Scrambles
Discussion in 'Women's Forum' started by bbbom, Nov 12, 2003.
  1. bbbom
    bbbom Subscriber
    Aug 13, 1999
    2,101
    How do you women with longer hair protect it from getting chewed up by your helmet?
    I have always had long hair but over the last few years, my helmets (dirt, street, snow & MTB) have broken it off so bad it looks like it's layered and not by a professional.
    I finally chopped it all off above my shoulders and I don't like it!!! I can't tie it up in a ponytail and it bugs me when it gets in my face.
    I have tried french braids, regular braids, ponytails etc. but with all of the different methods of tying it back it ends up squashed down into a tight little braid within a few hours of riding!!
    I have also noticed that the foam insert in my helmet grabs the hair & pulls it out so that doesn't help either. Rubbing between the helmet and my coat collar & chest protector doesn't help either so I need to tie it back (well as soon as it grows out more!).
    Is there anything out there that I could line the inside of the helmet with and tie my hair back?
    I want to grow it out again but if I can't stop it from breaking off then I'm going with the Susan Powter look!!! (hey, then I would look like pinball!!!!) :laugh:
  2. GETMETOCA
    GETMETOCA Can't Wait For Tuesdays
    Mar 17, 2002
    4,931
    bbbom, I'm sure your new 'do looks just fine!  Try setting it in hot rollers for a couple of minutes right after you dry it.
    I use a Scrunchie and leave it right below and outside of the helmet line.  Now that your hair is shorter, try using a wide and flat barrett with the bulk of your hair inside your helmet maybe?  Or a 'doo-rag?
  3. GETMETOCA
    Mar 17, 2002
    4,931
    Not sure why your hair is breaking off though.....Try changing products? Try Pantene ProV?
  4. dirty~d~
    dirty~d~ Resident nudist
    Apr 17, 2002
    2,030
    Have you tried a 'do-rag'? (I'll bet you can find one to match your purty bike. ;) ) I know they make them thin enough so your helmet will still fit. When I can remember to wear mine it helps. Your hair ends up looking mashed, but the trade off is it won't get chewed. Good luck, chica. :thumb:
  5. bbbom
    bbbom Subscriber
    Aug 13, 1999
    2,101
    That's why I've always had straight long hair - no muss no fuss, wash it, comb it & hit the road. Short hair is too much work for me.
    I think it may be my well water - very low PH. Might have to get a water treatment system probably would stop my fixtures from melting into the sink too, nasty green rings!!
    I'm looking for a do-rag made of silk or something similar - cotton seems to be too rough.
  6. bratt
    bratt Pain in da butt
    Mar 22, 2002
    217
    Try two braided pig tails. I have shoulder length hair right now and this seems to work out pretty well. Previously my hair was too short for one pony tail and thats when I discovered I could still part it in the middle and wear pig tails, unbraided at first.
    Also if you are looking for a no fuss styles with the short hair. Try using a pomade or a texturizer. Rub some of that in your hair and ta da the touseled, sexy look. Prep time 5 minutes.
  7. ChknLittle
    ChknLittle Subscriber
    Nov 7, 2003
    27
    Hubby LOVES my pigtails! :)
    Wear 'em very low or your helmet will push down on the rubber bands and give you a headache (even when you don't think it's pushing).
  8. firecracker22
    firecracker22 Sponsoring Member
    Oct 23, 2000
    3,240
    Bbbom, you have fine hair like I do. My shorter hair definitely seems to help, but I went shorter than you did, and it's definitely higher maintenance. It now involves mousse, hair dryer, round brush, hot roller, curling iron, spiking gel and wax . . . anyway, I think Diane's idea of a do-rag is the best. I started wearing one quite a while ago and they do help quite a bit . . . and they also help cut down on helmet odor too.
  9. KDXgirl
    KDXgirl Rookie DRN Member
    May 10, 2003
    146
    Umm can anyone tell me what a "do" rag is?
    and has anyone got any suggestions for keeping fringes out of the way and how do those girls keep their hair looking reasonable under the helmet?
    When I take my helmet off (and I have long hair in a pony tail) is is sticking up and knotted ever where, I give new meaning to the afro!
  10. firecracker22
    Oct 23, 2000
    3,240
    Do rag is a bandanna or scarf tied around your head like a pirate.
    By "fringe" I'm going to assume you mean "bangs?" Short hair hanging over your forehead? What I usually do is put my head into my helmet forehead-first, then pull the helmet down and back, and the helmet pushes the bangs up and back and keeps them there.
    As for tangled hair, that is exactly why we're discussing do-rags and stuff. There really aren't many alternatives.
  11. KDXgirl
    May 10, 2003
    146
    Yep fringe meaning the bit on your forehead! Never heard it called bangs before!
    Bandanna sounds a good idea.
    If I tuck my fringe up in the helmet it sticks straight up in the air for the rest of the day and is too long to have it sit flat like it is meant to cause the helmet makes it longer and then its in my airs. 2 girls rode at the track on the weekend and both their hair which is similar to mine sat perfectly, Id love to know their secret
  12. RockyRoads
    RockyRoads Sponsoring Member
    Aug 28, 2003
    88
    KDXgirl--If you find out the secret of the two girls with fringe, PLEASE let me know! I have bangs that, like yours, will either flatten out and get in my eyes, or if I tuck them up into my helmet, they will stick out once the helmet comes off. So attractive. I usually don't care what I look like when I'm riding--however, I actually had a guy that I was parked next to tell me that having my bangs down in my eyes made me look "frazzled". I just laughed it off (but, the nerve!). :| Anyway, I haven't quite figured out how not to have "helmet hair" after riding. I usually wear the long part up in a pony tail on top of my head, off center so that the pony tail holder hits an open space in my helmet and doesn't dig into my head. I don't have any problems with breakage--just the squashed (and apparently "frazzled") look with my bangs.
  13. GETMETOCA
    Mar 17, 2002
    4,931
    TOO FUNNY!!  I can't believe the nerve of that guy!  I had a job feeding dairy calves at 4 a.m. and one of the milkers noted that I looked......"rough" as he put it.....I didn't brush my hair or put on lip gloss that morning, yanno, saving the bling for when I took a shower.  I'm sure the calves were appalled as well. :silly:
  14. husky2kawi
    husky2kawi Rookie DRN Member
    Sep 13, 2003
    17
    LOL,
    LOL,
    LOL.
    Pam
  15. dirty~d~
    Apr 17, 2002
    2,030
    The nerve is right! I doubt he was any kind of Spring Chicken himself. As for the cows they do tend to get particular about such things. Next time you should really keep their feelings in mind Nat. :confused:
  16. Michelle
    Michelle Sponsoring Member
    Oct 26, 1999
    1,245
    http://www.whitehorsepress.com/onlinecatalog/sections/proddata/hg.htm
    Don't know if it works or not, but maybe worth a shot? I know when my hair was longer I'd tried just about everything & then decided short was the way to go - only problem is getting organised enough to get it trimmed regularly, but if I go within a year, it'd be amazing (my hairdresser is selling the business so I must get there before she does quit). Henk basically got sick of spending a couple of hours a month trying to get the knots out, as I never could, but with a ponytail I was able to hide them lol
  17. TwistNShout
    TwistNShout Rookie DRN Member
    Nov 19, 2003
    283
    My hair used to be layered, and it seemed as though only the short parts of my hair were what used to get tangled.
    Now that I have grown my hair out--all except for some whispy bangs, I don't get tangles anymore. I simply braid my hair in a tight ponytail until I'm done riding. Personally, for me, I have found it healthier & easier to keep my hair long rather than short for our sport, but I am sure it depends on the texture of one's hair also.
    Maybe your cosmetologist could give you some helpful tips for your particular hair type or needs?
  18. pyrofreak
    pyrofreak Rookie DRN Member
    Apr 9, 2003
    819
    A do-rag will work fine for this problem. I've used a do-rag for softball also. I usually make a freind put mad tiny little braids in my hair, or have corn-rows put in though. Works great for me, and my hair is not fun to take care of. Long, blonde, striaght, fine hair. Cant do to much with it.
  19. LoriKTM
    LoriKTM Super Power AssClown
    Oct 4, 1999
    2,261
    I've pretty much given up on having decent hair after I ride.  I just try to remember to bring a hat with me.  "It's to protect from the sun".  Yeah..that's it. :confused:   Because if there's anything worse than long, blonde, fine, straight, hair it's long, blonde, fine, CURLY hair.  Naturally curly = naturally frizzy.  A little riding, a little sweating, a little mud and forget it.   I'll brush out the back, and then throw a hat on to cover up the bangs which are pointing every which way.
    If I'm casually riding, I'll just tie the back in a pony tail.  If I'm going out for an enduro or all day ride, I'll braid it.  The braid is much easier to comb out afterwards, and doesn't collect little mud balls as easily as a loose ponytail.  Haven't tried a do-rag.  My head sweats enough as it is, I don't know that I'd want another layer trapping heat.
    I haven't really had any problems with breakage, but then again we have a water softening system in our house, which may help.  I use conditioner every day as well.
  20. bbbom
    bbbom Subscriber
    Aug 13, 1999
    2,101
    I'm going to try the do-rag. My braids even end up smashed into tight little twists when I'm done riding.
    Snowmobiling is even more fun - seems my hair ends up with snowballs in it!
Similar Threads: Hair Scrambles
Forum Title Date
Women's Forum Helmets and long hair Jan 10, 2008
Women's Forum To cut my hair, or not? Oct 20, 2001
Women's Forum Illinois Lady Riders... anyone racing in the Dist 17 Hare Scrambles? Jun 2, 2009
Women's Forum Harescrambles May 11, 2009
Women's Forum Are there any other ladies racing the D36 Hare Scrambles? Nov 2, 2002
Share This Page
