eric whats the best way to set up a head for methanol fuel for a road racing sidecar. my compression ratio is set at 13/1 . full stroke. peak rpm is 9000 just not sure on the squish area and more important the MSV. it an kawasaki h2 750 :ride:
Normally you want a wide squishband say 60% of the bore area with a 2 degree greater angle than the piston, and a minimum squish clearance at the edge of 1mm
An H2 with a sidecar? I never thought of using a sidecar to make tose bikes handle, thats very clever!
