Help!! Cant Bleed Clutch Line
I am in the process of putting my 99 250 exc back together after the horrible tumble off the trailer. Just installed a new clutch line but I am having trouble bleeding the line. The syringe will hardly even compress and when it does the oil seems to seep out at the top of the bleeder nipple. What could be my problem? I am new at this so I dont really have any ideas. I am so close to having this thing back up and running, so I would greatly appreciate all your help so maybe I cant get back out in a few days.
Thanks!!!
1999 KTM 250 E/XC
Remove the master cylinder cover? I'm guessing.
Gary
It's not how fast you can go but how much fun you have!
Strick,
No Luck. I loosened both line fittings but to no avail. The m/c cover is off. Maybe I have the cheapest syringe money can buy! HA!! It is very frustrating when your trying to learn to wrench on the bike and little things like this pop up.
Any other suggestions before I take her to the shop.
1999 KTM 250 E/XC
Strick
Lifetime Sponsor
First things first. The reservoir cap is off. The clutch line is unobstructed. The bleed fitting is un-tightened. Here's a couple of more things to try. Try pulling the fluid backwards from the reservoir to the syringe. Pump the lever a couple of times with the fitting loose. It has been a while since I have done this. I will rack my brain to see if any thing else pops up.
Strick '99 KTM 300mxc, AMA & BRC member
I will give it a try tomorrow and let you know how it goes. If you have any more ideas post them and I'll get them in the morning. Thanks for your help.
1999 KTM 250 E/XC
jeb
Sometimes you have to loosen the bleeder valve quite a ways to make it easy to push the fluid in. If that doesn't work, I'd check the line or banjo bolts for obstructions.
John Brunsgaard - JEB
01 KTM 400 EXC
99 KTM 250 EXC
99 KTM 200 EXC
98 KTM 125 EXC
98 KTM 380 MXC (gone)
96 KDX 200
I had the same thing happen to me when I was back bleeding the line. This is what I used and what I did.
I bought a syringe from Wal*Mart ($2.00)in the boat isle I think and two 1/2" hose clamps ($1.00) and used a pice of gas cap line. I fitted hose to syringe and clamped with one hose clamp. I then pushed hose and last hose clamp onto bleeder nipple. Once on tight and clamped loosen the bleeder nipple and push the fluid. I remember it was quite stiff to push the fluid through but put some a$$ into it. You will need some one to catch the fluid which spills over at the m/c and watch for the air bubbles to disappear in the line. Once that occours spin the syringe to close the nipple and then tighten with box wrench. You will need to remove additional fluid at the m/c (4mm below rim) before closing it up. Remove the syringe and pump the lever to regain pressure, Then recheck level of fluid. Good luck. Hope this helps.
01'520E/XC
I will be installing a stainless steel clutch hose on my bike very soon and this thread got me thinking... is there a way to bleed the system with my mity-vac?
thanks
Jay
2001 KTM 250 E/XC
NETRA & AMA Member
Chicken Wrist Racing
TWIST IT!!!!
jeb
Sure, vac pumps works too. Just make sure to have someone adding fluid at the resevoir.
01 KTM 400 EXC, 99 KTM 250 EXC, 99 KTM 200 EXC, 98 KTM 125 EXC, 98 KTM 380 MXC (gone)
96 KDX 200
When you put pressure on the syringe, pull the clutch lever all the way open...in the resting position the lever puts just enough force on the plunger to close the line if you have the release point adjusted...this happened to me the first time I tried bleeding my clutch
Gary
I bled mine like this...<fill resivoir,tighten all fittings and bleeder, pump the clutch lever several times and hold, open bleeder slowly, closeand repeat until fluid comes out of the bleeder. You will need to fill the resivoir a couple of times during this operation....
Katooms rule
C -
When all else fails, go to the book. It may seem trite, but one of the first things I did was buy the KTM-issue syringe, tube, and special fitting that replaces your bleeder fitting at the bottom. When I have worked on my clutch, I have left the remaining fluid in, and sometimes have drained it all out to get a fresh start. Either way, the KTM rig works very well. It cost me a few bucks, but compared to what you've been through, it was well worth the several hours of frustration you've endured with no results. I'll spend a few $$ to save some time any day!
"You can do ANY job if you have the right tool."
Jack
I bought a mighty vac thinking it was the cure to my week long clutch bleeding adventure but it didn't help.
The prob I discovered was small air bubbles in the master cylinder that I could get to bleed out. I finally read the manual and pushed the fluid up from the slave cylinder using some fuel line and a cap off some differential lube. I removed the bleed screw and pushed atf from the bottle until it appeared in the master cylinder. This takes some time. I then quickly screwed in the bleed screw. There's no need to bleed cause there's no trapped air in the slave cylinder to bleed.
2001 KTM 400SX #529
2000 SVCC 125cc H.S. #1
SPONSORS: MA'S CYCLE, SIDI, WD-40, ACERBIS, SMITH, SPROCKET SPECIALISTS, N-STYLE, WER, DEVOL.
