I bought a 1983 honda cr 125 from my uncle for $300. He bought it from a garage sale for $500. He only rode it a couple times.
I tested it out it started on the 3rd kick. And rode it around for like 10 minutes. It shoots oil out the exaust and all over the tailflap.
When i got it home i drained the oil. Put new oil in. Drained the gas put new gas in. And checked the radiator. It was empty so i filled it up with water. Then i tried to kickstart it. And it ran for about 30 seconds. Then the engine bogged down. When i looked into the radiator after it shut off the water inside the radiator was a milky grey. I tried to kick it a few more times until i realized that the radiator fluid got into my engine. I took off the exaust pipe connected to the engine and kicked it over once and a crapload of water spray came out. You could also feel the water when you try to kick it over.
I was wondering if anyone knew what could be wrong.
if it is even possible to fix.
Is it worth it?
please help. I'm out $300 with nothing to ride.
Is it worth it?
