Installed an EE braided clutch line on my sons 65. Back bled the system till no bubbles coming out at master cylinder. However, still have no feeling/pressure at clutch lever!
Check it out at Mityvac.com it will tell you pretty much that it's a hand operated vacuum pump. I think I got mine for a whole $10 at Harbor Freight but have seens them at most auto part stores. Be sure to get the one with the dial gauge to make it most useful.
The best way is to use a syringe (I use one from discount auto parts made for measuring lawnmower premix). You take the top off the resevoir on the bars,, remove the bleed screw from the slave cylinder on the cases, put the full syringe in the bleed screw hole and push all the air and old fluid out from the bottom up. Sometimes you have to crack the clutch lever a little while pushing on the syringe. You have to push hard.
I like them myself, Dad.
I fill my clutch with ATF and the feel is a bit lighter than with the stock mineral oil.
I have to agree with yota....I have one of the syringes like his (several actually) but you can also use a cow syringe from the farm supply for about 3 bucks for a pack of 3.
