HONDA CR 250 carb setting
Discussion in 'Big Bikes' started by kid100, Feb 5, 2002.
  1. kid100
    kid100 Rookie DRN Member
    Jan 18, 2001
    40
    I am not content with the original carb setting! It run to rich and I want more overrev!!!! :ugg:
    Did someone find a solution??
    THANKS!!
  2. JTT
    JTT Subscriber
    Aug 25, 2000
    1,410
    maybe a little more information might help...year, temperatures, altitude, riding type, etc. Also do a search, there have been too many "jetting" threads to mention.
  3. kid100
    Jan 18, 2001
    40
    Sorry!
    Honda CR 250 / 2002
    temperatures: 10-15° celsius
    altitude: 300meter over sea
    riding type: only motocross, no trail riding or enduro
  4. Corn
    Corn Rookie DRN Member
    Nov 6, 2001
    8
    Here's what I'm running in my '02 250
    Sea level 40-55 deg F, MX only, some Sand.
    30-73 2nd or top clip
    35 pilot
    410 main
    air screw stock +- 1/4 turn
    As you can see way richer settings than stock. The bike is stock. The 02 CR will scream up on top when you richen it up, it's like a different bike. Riding in the sand requires a rich setting too. The only battle is having a clean bottom end. I will never run anything less than a 400 main even when it gets to 90degF. I just change pilot back to stock and play with differnt needles and clip positions. I think if you start with limiting your main jets to a couple and make that your starting point the bike won't lose that top end. I've heard talk about running a 4.0slide (4.25 is stock) and also changing the brass part the needle goes into from an s9 to an s8. Not much help here, anyone?
  5. TOTALL
    TOTALL Rookie DRN Member
    Feb 21, 2002
    143
    02 JETTING
    HERE'S MY SET UP FOR NOW
    PILOT 32.5
    MAIN 390
    STOCK NEEDLE IN 2ND POSITION
    STOCK PIPE AND SILENCER
    AIR SCREW 11/4 OUT
    I'M 900' +- ABOVE SEA LEVEL
    LAST TIME I RODE IT WAS ABOUT 55-65 DEG BIKE WAS ALITTLE RICH ON THE BOTTOM NEXT TIME I RIDE I'M PUTTING IN A 30 PILOT AND A V-FORCE REED VALVE.ALOT OF PEOPLE ARE PUTTING IN THE S8 NOZZLE HAVEN'T TRIED IT YET MAYBE WHEN IT GETS WARMER :think ANY THOUGHTS
Similar Threads: HONDA carb
Forum Title Date
Big Bikes 2005 Honda CR125 carb basics Dec 24, 2007
Big Bikes Honda CRF 250R Which CDI and CARB Dec 1, 2005
Big Bikes Honda CR 125 Mikuni TMX 38mm Carb Apr 20, 2005
Big Bikes Carb needle source for Honda? Jan 22, 2002
Big Bikes 1991 honda cr 500 carb Nov 6, 2001
Share This Page
