How much goes to 2004 YZ450F forks?
Kasjok
76
Ok, if someone has a 2004 yz450f manual then please tell me those numbers, please! If not, I will try this 4-5" system.
Kasjok
76
Please, I need correct numbers and I weight 90 kg with my gear on, I thnk it`s about 200 lbs or a little more.
Cheater
129
I have a 06 manual, I says 6.59 us oz
It says the oil level should be 145-148mm (5.71-5.83 in) from top of fully streched damper assembly.
Kasjok
76
05 and 06 yamahas have dual chamber forks or am I wrong? Mine have single chamber forks.
Edit: If it helps then i ride only MX.
Matt90GT
1,517
The 05+ is twin chambers. Totally different. I have done about a dozen of the 04 YZ forks in the last year and they have all worked great. Start low on the level and then add about 10cc per leg if you are still bottoming.
If I remember correctly, the older KYBs have a measurement in the manual, no oil amount.
