Husky 50
I just picked one up but cannot tell what year or model. White plastic with blue. yellow fenders,conventional forks,cable operated disc brakes,10inch tires,small size exhaustpipe. I think this is an early one. I can't find any frame numbers anywhere. Does anyone have experience with these. What problems am I facing? I need a throttle cable. Who is a good dealer for these bikes? Thanks
Marc
Is there any way you can post a pic and is your motor air cooled or liquid? There are few ppl that deal in parts but I need to see it to point you in the right direction.
- a d v e r t i s e m e n t -
First off, the VIN # will tell you the year, Above the VIN # should be a model type like S501. The carb. will get us close on the model, 14mm or 19mm carb? most likely a SR. since it has a disc brake, so most likely a 19mm carb.
